Thanks.
Did you just hear that giant sucking sound. Ouch!!
Your engine shop can figure what you need to mill off the heads to make the intake fit. And you don't need full groove bearings. Again I'd ask your engine guy what he recommends and prefers to use for bearings. A cheap internet price isn't always a deal.
As noted, the full groove bearings will give more oiling to the rod bearings, as they can get pressure full time, rather than half time. But it will take some pressure away from somewhere else, like the cam bearings, or the left side oil lifter gallery. The HV pump will help keep up that pressure, especially at the lower RPM's and idle.
So I have been reading a little about solid roller cams.
Is it possible to run one in a non roller block?
Are you sure you want that high RPM range operations that come with the roller cams, 'specialy the sold ones? I looked at Crane, Howards, and Lunati catalogs so far, and only Lunati had a Voodoo hyd roller cam profile suitable for low-mid RPM operation; the other 2 mfr's only had roller profiles suitable for racing.
I have just been looking at hyd roller cams in an LA 360 block. Looks doable, buuuut.... As I understand things as this moment.....
The one issue was that the waist band in the original lifters was made for lifter bores higher in the block, and, when put in the standard LA block, the waist band could pop up above the top of the lifter bore, and bleed off the oil pressure in the gallery and the whole engine.
Another issue is that the standard roller lifters may need the lifter bores bushed....expensive.
Hughes has a set of hyd roller lifters that have the waist band located lower and MRL has a set of solids the same way. There may be others who make these. And there may be other options that others can suggest.
BUT, for a budget build....ix-nay on the ollers-ray ! These modded lifter sets are $400-$600 bucks, and the roller cam are in the $300 range......You may save the $$ on the modded lifters by doing the copper tube & peen process on the galleries or other various oil restriction mods, but not sure if you can get around the lifter bore bushes. Bottom line: Flat tappet cams exist for a reason... much cheaper.
Are you sure you want that high RPM range operations that come with the roller cams, 'specialy the sold ones? I looked at Crane, Howards, and Lunati catalogs so far, and only Lunati had a Voodoo hyd roller cam profile suitable for low-mid RPM operation; the other 2 mfr's only had roller profiles suitable for racing. I am looking them just for a race (rally) build and want a wide torque range with the ability to use lower zinc synthetic oils.
