tguss
i have a 78 heavy duty 360 four barrel and 727 trany came out of an rv with 52,000 miles. i drove rv befor pulling motor and run good, i now have motor pulled apart to install new gaskets and paint. motor have the 596 smog heads i have already pluged off the holes. this is going into a 68 valiant 2 door to replace the 273, what would be a good cam for this motor ? it will be street driven, im installing headers, alum intake, useing the 727 trany and converter that came out of the rv, the bottom end is stock and i think compression is like 8.4 to 1 any idea on cam for this setup ?? thanks
