Muscley MOPAR
does anyone know if anyone makes a main cap girdle for a 360
well itll be a 500 plus motor so it couldnt hurt, the less walk the better more support
4 bolt mains are for chebbies... Save the strength of the block and use two-bolt studs. Should hold up plenty well with a balanced assembly.
A 4 bolt main a Chevy thing? Incorrect! It certainly is a strength item not limited to Chevy. MoPars can use a 4 bolt main and they did come stock on the AAR - T/A cars. There a worthy upgrade, but, I myself would only use the 4 bolt main when it comes with the race block. I figure, IF I'm going to build a monster of a motor and it could use/need a 4 bolt main, I'll step up to a race block. Since it'll be a seriously built high horse power engine. Well beyond a mere 500HP street engine.
The stock block will take a good bit of power. Hard blocking it and on a good core with thicker than normal cylinders and other such things can more the power abilities up some, but it is a stock block and it does have it's limits.
I'll yield at 500 for the street. It's a lot of stress for the engine at this level, for the stock block and daily or semi daily usage. Weekend blaster... Ok, maybe more, but.... IDK about that for long life.
(All ways a catch 22 going on and what your willing to live with.)
