360 head ?
DartDave
Fairview,TN
I was told they are 360 heads, the only #'s below the valvetrain are 345, besides the time stamp. Just below the exhaust ports are air injection ports which are plugged with set screws.
Anyone know what the heads are off of ?, what year?
Thanks again. :salut:
First look for a 7 digit casting number on the intake runner and check and measure the valve size if you can.If you have a small hole just below the exhaust port you have the 360 air pump heads.Now are these heads magnum heads or the old school heads? Some of the casing numbers for the 360 are these:
LA Engine Cylinder Heads Casting Numbers
Casting Number Engine CID Year Intake Exhaust
2465315 273 1964-65 1.78 1.50
2536178 273 1966 1.78 1.50
2658920 273 1967 1.78 1.50
2843675 273 1968-69 1.78 1.50
2658920 318 1967 1.78 1.50
2658234 318 1967 1.78 1.50
2843675 318 1968-74 1.78 1.50
3769973 318 1975-83 1.78 1.50
4027163 318 1977-86 1.78 1.50
4027593 318 1977-84 1.78 1.50
4323302 318 Fast Burn 1985-86 1.78 1.50
4323345 318 Police 1983-86 1.78 1.50
2531894 340 1968-70 2.02 1.60
3418915 340TA 1970 2.02 1.60
3418915 340 1971-72 1.88 1.60
3671587 340 1973 1.88 1.60
3418915 360 1970-72 1.88 1.60
3671587 360 1973-74 1.88 1.60
3769974 360 1975-76 1.88 1.60
3671587 360 1976 1.88 1.60
4027569 360 1977-86 1.88 1.60
I know the heads were modified there's 2.08 intake valves in there now. I'm not sure if these are the old style or not.
Thanks for the reply. :salut:
And they're currently mounted to the block. I pulled the intake in order to blast the body paint he used on the engine. NOT HIGH TEMP ENGINE PAINT.
Dave, if you take a small mirror and light and look under the head you will see a casting number in the lifter valley under the intake ports.Go to my old site,or click o the link to see what I mean,mrmopartech
Thanks Mrmopartech, Love that site tons of usefull info. THANKS AGAIN
I'll guess they are the newer style as the numbers are 4448308. :salut:
I believe those are 89-92 swirl-port 360 heads...pulled a set and the A-518 tranny from a '91 D-250 van at the local 'Pull-A-Part' for $135 last summer. Casting number on the heads had the 308. Suppose to be a very efficient head and a good candidate for building a well-rounded engine.
