D
Deleted member 49442
Guest
Hi Guys,
Looking for some assistance in tuning my LA 360 short block.
What I have:
Mopar LA 360 it has a 9.5 compression ratio
Comp Cam #20-221-3
20-221-3 - Xtreme Energy™ Hydraulic Flat Tappet Camshafts
stock j heads
Mopar Orange box ECU with new distributor (haven't touched the vac advance adjustment)
318 exhaust manifolds (Truck)
Rebuilt Thermoquad Carb
I usually run 87 octane
Torqueflight transmission
3.55 gearing
Tire size p225 70R15
Bosch Platinum plugs
What I'm experiencing:
Terrible gas mileage 8mpg
Light pinging under load, up long steep hills
Also seems like this should have more power than it does.
From my service book with a Mopar 360 8.6 compression ratio it says timing should be set to 4 degrees btdc (The sticker for my vehicle states it should be at 10 degrees btdc)
What I did:
I started by leaning out the carb.
Took the fuel enrichment screws in ½ turn each are now out 1 & ½ turns
Took it for a test drive and it was majorly pinging
I checked the timing (with the hose pulled off the vac advance and plugged)
and found it was set to > 10 degrees btdc (off the scale)
I changed the timing to 8 degrees btdc
It was back to Light pinging but now dieseling
I think my dad slowed down the idle to remove the dieseling.
So my questions are:
With my setup with a higher compression ratio engine than stock what should the timing be set to? (I'm thinking it should be lower than 8 degrees, maybe around 4 degrees btdc)
Should I be running higher than 87 octane?
When I have initial timing set do I need to mess with the vacuum advance timing adjustment?
I bought some timing tape so I can dial it in with more accuracy.
Its winter here in PA, so I wont be able to take it out for a test drive for a while, just wanted to get on top of this asap.
Thanks
Michael
What I have:
Comp Cam #20-221-3
stock j heads
3.55 gearing
What I did:
Thanks
Michael
