Ya know what.....I think that I am going back to my original, original, original plan when I first bought the motor. Low dollar with good fun factor. I found a build on FABO that I think will fit my needs nicely. I may swap out the pistons if they can get me a little more compression but I may not. I already have the EQ heads with Comp springs, 3.55 gears, 2500 stall converter, Patriot headers, 600 1406 carb. Will use Crosswinds intake, .028 head gasket and H pipe. Of course new HV oil pump, bearings and rings. I may also treat myself to a new Holley 670 street avenger.
Here's what I found:
"Buy a Magnum 5.9/360.........buy EQ CH318b's assembled. Send roller cam for regrind (210/215 @.050" 112 LSA about .475-.490" at valve) Edelbrock RPM intake, stock rebuilt bottom maybe .020" -.030" stock cast pistons etc.. Start, idle will be amazing, expect to smile when foot is above 1/8-3/4 throttle, enjoy 370-400 HP and 430-440 ft/lbs on 87 octane. 360's are the way--tons of torque so you can cruise @ 75mph all day with a sane gear. " Posted by member RAMM.
