360 main bearing differences by years?
Remow2112
I have a 72 360. Went to by main bearings and discovered that the bearings for the mains are listed by year. 71-73 then 74 and up.
I have searched on here and google and can't figure out the difference. Can someone enlighten me? (The 74 and up bearings everyone has in stock. The 71-73 no such luck.)
Thanks,
Dan...
thrust bearing is different...which is no. 3 main bearing...
Thanks for the info. I found some online and got them. I was just hoping to find them in town so I could do the bottom end this weekend.
It is kind of funny. Mopar must of still had a bunch of the older 360 bearings laying around because I have a 75 360 that has the 71-73 style bearing in it from the factory. But you can see it is cut for a larger flange.
I wonder why they changed it?
Dan...
It appears that the last time I did the motor (72 casting 360) I bought 74 and up bearings. They fit and seem to work fine. MY new and proper (71 - 73) bearings came yesterday. When you put the #3 (71-73 style) bearing in you can see it leaves a lot of of the machined recessed viewable. When I put my old bearing on it almost completely fills the machined area.
I will get a picture tonight. It is really starting to look like any 360 mains will work. Anybody have any insight on this? I am really curious. I could have bought the 74 and up bearings in town no problem. Had to order the 71 - 73 bearings.
This great to know because the 74 and up bearings are much cheaper.
I also have a 75 360 block laying around and the flange cut / recess on #3 appears to be the same size as the one in my 72 block.
Dan...
Dan...
Good info Dan. Thanks for sharing. If you can get a couple pics that'd be even better. I always knew there were 2 different bearing designs used but never had an old and a new block to make comparisons. I am re-building a 73 360 right now and bought the bearings for a 73. Wish I had known the 74-up bearings would have worked because they are alot cheaper and sounds like they have more surface area for thrust.
BTW: did you look at the thrust area on the crank to see how the 2 different bearings line up to it? I wonder if the thrust flange for the older 360 crank is any different? I'm using a stroker crank in mine so I have no stock stuff to do comparisons with.
I am interested in this too. I have a '70 casting 360 block and a '73 360 block I would love to save some money on bearings. Anyone have the low down?
I just found out something interesting. I looked up the bearings I bought for mine and find out they are spec'd for use in 1970-1991 engines. They are the performance 3/4 groove Speed Pro Z120M bearings. All other brands (even the perf. series) have the split in yrs. but Speed pro don't.
Pic 1 is a 74 and up bearing in rear and 71-73 in front.
As you can see the 74 and up has a taller thrust flange.
Pic 2 is the same bearings opposing each other. Easier to see the flange width difference.
Pic 3 A genuine 1972 360 #3 main cap. You can see the machining for the flange to sit.
Pic 4 is the 74 and up bearing on the #3 cap. You can see the the flange covers most of the recessed area on the main.
Pic 5 is a 71 - 73 bearing mounted on the same #3 cap. You can real well in this pic how much smaller the flange is.
I think that the bearing changed in 74 when they started putting 360s in A bodies. You could get a standard tranny in the old A body. Prior to 74 they only came in large c body type cars which did not come with a manual transmission. So a larger thrust surface is need when you have a manual transmission.
As a side note. I was running the pictured 74 and up bearing in my 72 360 just fine and by accident. So I think it is safe to use the 74 up bearings regardless of the year of motor, or so it appears... 8)
Dan...
check the bearing tang in the #5 main cap thats the difference
