chasonmarose
Active Member
I have a 360 In my 74 d 100
My build is as followed
.040 bore
.040 crank and rods
3.58 stroke
4.040 bored block
Xe275hl comp cam .525/.525 275/287
Kb 107 pistons
Stock rods
Stock crank
Holley strip dominator high rise intake
Holley street avenger 670cfm
Stock heads 2.02 Intake 1.60 exhaust
Flow tech long tube headers
True duals into flow master super 44s
Ignition is a hei Chevy style 50000 volt it supposedly does
Timing set at 35 degrees with mechanical once vacuum advance is hooked up about 60 degrees around 3200rpm
What compression and hp do I have??
Oh and my heads I don't see a j or an X on them no casting number under valve cover on intake runner either. Has the half moon heat exchanger on the heads tho. No idea what cc they are
.040 bore
.040 crank and rods
3.58 stroke
4.040 bored block
Kb 107 pistons
Stock rods
Stock crank
