Not-A-Duster
Hello,
I have an issue with my Dart. It is a 71-74 360 (casting 3418496 - 7 - 360) with crappy 318 heads (casting 2843675 / 2533) with an Edelbrock Torker 340 intake and Edelbrock 600cfm (1406) carb. Everything else is stock. The car has the stutter/hesitation when easing into the throttle from a stop. I checked most everything. The idle is at 14 degrees initial and 34 w/ advance with the vacuum advanced plugged. The accelerator pump linkage is in the middle hole and it looks to be working good. Trying to adjust the carb using a vacuum gauge like normally suggested I noticed that the car has 0 vacuum at idle. As soon as I rev it at all it goes to 15 but at idle it does not register. I checked for vacuum leaks but can't find any. It does look like the emissions stuff was removed from the 360. Since there is not smog pump is this why the idle vacuum is so low? Would the vacuum issue relate to the stutter or am I chasing a non issue? Any other suggestions?
Thank You for your time.
