360 runs great one day and then poorly the next
Small Block Mopar Engine
  1. crewchief
    crewchief A & P Mechanic
    265
    63
    Jan 17, 2014
    Malta NY
    Local Time:
    1:09 PM
    Hopefully someone out there can point me in the right direction. My brother-in-law has a 360 with a fresh rebuilt Thermoquad and having running issues.
    New engine compartment wiring, good coil, ballast resistor and electronic ignition module, new distributor and fuel pump. There's no intake leakage and fresh fuel in the tank. Even swapped the TQ with a new Edelbrock with same results.
    It didn't matter with air cleaner on or off before. Started it today with air cleaner off and began to ran poorly once again. Installed the air cleaner and it began to clear up. Prior to today, with or without air cleaner installed had no adverse effect. When air cleaner is off the port on the carb is capped.
    Shut down and started back up an hour later and would not run like it did before. Runs terrific one day and then the next day runs like crap. Park it for a few days after running good, fire it up a few days later and wouldn't run as it did when parked. There's a gremlin running around!
    Any guidance would be appreciated. Thanks, Jack
  2. dukeboy_318
    dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
    32,419
    11136
    Jan 19, 2007
    la la land
    Local Time:
    1:09 PM
    Question, was the weather drastically different? As in was it raining the day it ran badly?
    Reason I ask is that forever, the 408(360 based) in my w200 would do that. Every time the humidity was super high or it was raining, thing was a stumbling mess. Finally replaced the ignition box(which was a new one to begin with) and that solved the issue
    • Like Like x 1
    • Agree Agree x 1
    • crewchief
      265
      63
      Jan 17, 2014
      Malta NY
      Local Time:
      1:09 PM
      No, the weather has been very nice. Humidity is low based on our location. It's been acting up with either a replacement box or the one that was installed for years (known good).
    • dukeboy_318
      32,419
      11136
      Jan 19, 2007
      la la land
      Local Time:
      1:09 PM
      Cool good luck.
    • Biff
      Biff Well-Known Member
      2,197
      1776
      Jan 30, 2017
      Vancouver island
      Local Time:
      10:09 AM
      Try reving the engine closing the choke plate , till it just about stalls then let it rev up again , if there’s a chunk of chit floating around it will sometimes pull it through. Try several times .
    • nm9stheham
      nm9stheham Well-Known Member
      10,701
      2892
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      1:09 PM
      Ignition related:
      • Ballast resistor part number?
      • Is the ECU case well grounded?
      • Check/clean all electrical grounds to block, battery, and body
      • Reluctor gap set to.008" with non-magnetic feeler gauge?
      • Does the distributor shaft have excessive sideways wobble?
      • Use a voltmeter to check voltage to coil + when idling, with the - lead of the meter to battery -; typically will be in the 6-9 volt range running
      • Remove the coil high voltage lead from distributor and place near a metal surface; crank engine and see that spark jumps at least 1/4" in open air. Repeat test with a single lead off of one of the spark plugs when idling.
      Intake tract:
      • What PN/type PCV is in there?
      • Check throttle cable and return to see if it returns the primary throttle to a consistent spot.
      • Check throttle blade stops on both primary and seconday to make sure the throttle blades are not come to rest against the side of the bores
      • Put on a vacuum gague to the intake manifold and take readings when runnign good and bad
      • Like Like x 3
      • Agree Agree x 1
      • crewchief
        265
        63
        Jan 17, 2014
        Malta NY
        Local Time:
        1:09 PM
        Thanks, I'll pass it along and see what he finds.
      • Mike69cuda
        Mike69cuda 64 is the new 17 FABO Gold Member
        695
        440
        Jan 2, 2018
        Overland Park Kansas
        Local Time:
        12:09 PM
        Cracked distributor cap? I chased that one for awhile....
      • crewchief
        265
        63
        Jan 17, 2014
        Malta NY
        Local Time:
        1:09 PM
        Cap is new and already looked it over.
      • dukeboy_318
        32,419
        11136
        Jan 19, 2007
        la la land
        Local Time:
        1:09 PM
        Sometimes, especially with the mopar ignition setup, the new parts are junk from the get go. I've seen ballast resistors and ignition boxes brand new, be junk.
      • crewchief
        265
        63
        Jan 17, 2014
        Malta NY
        Local Time:
        1:09 PM
        I've seen that as well. He swapped back to his old parts that worked prior to all this happening.
      • cojohnso
        cojohnso Well-Known Member
        97
        88
        Mar 25, 2019
        Minneapolis, MN
        Local Time:
        12:09 PM
        When you say running bad? Is it just motor? Or are the lights flickering? A short in the starter or starter circuit can interfere with ignition circuit. And make motor start popping. Even as something simple like a ground. The time I had starter was acting up too. So had a better suspect than what you are describing.
      • crewchief
        265
        63
        Jan 17, 2014
        Malta NY
        Local Time:
        1:09 PM
        It's the motor, no lights are flickering. Motor just acts like cylinders are dropping off. Next time everything runs just fine. It comes on goes, almost like its loading up but runs great the next time.
      • dukeboy_318
        32,419
        11136
        Jan 19, 2007
        la la land
        Local Time:
        1:09 PM
        Coil?
        • Agree Agree x 1
        • crewchief
          265
          63
          Jan 17, 2014
          Malta NY
          Local Time:
          1:09 PM
          New coil and reinstalled known good coil, no change.
        • MobileCustoms
          MobileCustoms Well-Known Member
          1,572
          1120
          Oct 21, 2013
          Inver Grove Heights, MN
          Local Time:
          12:09 PM
          I had a mis-aligned/cocked dist cap on my MSD distributor that acted similar.
        • crewchief
          265
          63
          Jan 17, 2014
          Malta NY
          Local Time:
          1:09 PM
          That was checked and found to be seated and locked
          • Like Like x 1
          • MobileCustoms
            1,572
            1120
            Oct 21, 2013
            Local Time:
            12:09 PM
            I'd swap out with a known-to-be-good carb for a comparison, if you haven't tried that yet
          • crewchief
            265
            63
            Jan 17, 2014
            Malta NY
            Local Time:
            1:09 PM
            He reinstalled the Edelbrock and found with same results, thus not a carb issue
            • Thanks! Thanks! x 1
            • MobileCustoms
              1,572
              1120
              Oct 21, 2013
              Local Time:
              12:09 PM
              One more thing.... Fuel pressure. What fuel pump are you running and have you verified the pressure is no higher than 6.5-7psi at most??? I had an expensive Edelbrock mechanical fuel pump guaranteed to put out only 6.5 but it was running 8+ psi. Went back to a stock mechanical $18 pump and smoothed everything right out.
            • JoeSBP
              JoeSBP RLTW!
              1,199
              636
              Jun 16, 2015
              NC
              Local Time:
              1:09 PM
              more detail on "runs like crap"
              Idle, cruise, WOT no load, WOT under load, does it every go from running well to abruptly running poorly, or does it only run poorly once it's started that way?
              I would start by closely checking all your plug wires, to include resistance, then checking all your wiring.
              make a list of your checks, then do the same checks with the engine fully heated up.
              And a part being new pretty much means nothing. Every part works correctly, right up until the point it no longer does.
            • MobileCustoms
              1,572
              1120
              Oct 21, 2013
              Local Time:
              12:09 PM
              I also want to add, that with my fuel pressure situation, I had the same poor (loading up) results with 2 new Holleys and a good Edelbrock carb, until I replaced the expensive pump with a stock cheapie. I could have achieved the same end results with a fuel pressure regulator, and still plan to add one of those soon.
            • crewchief
              265
              63
              Jan 17, 2014
              Malta NY
              Local Time:
              1:09 PM
              When fired up it would run perfectly. The next time, it would run like it loaded up push heavy exhaust. This is at idle, couldn't take it down the street too far without fear of dying. Other days it would run great, no issues even under load driving it around.
              So, it all depends on the day after it starts up. The weather is not a factor because it only sees nice weather on the road.
              Put the original parts back in and still would run just fine and then wouldn't.
              That's why the engine compartment wiring was replaced, thinking that was causing the issues. Again, works great and then not.
            • crewchief
              265
              63
              Jan 17, 2014
              Malta NY
              Local Time:
              1:09 PM
              The Edelbrock that was on it before the TQ was installed run fine for years. Stock fuel pump is working at required pressure.
            • MOPAROFFICIAL
              MOPAROFFICIAL Well-Known Member
              3,508
              2476
              Jun 1, 2016
              breakwater
              Local Time:
              10:09 AM
              Loosen and re tighten bolts holding down ignition box and voltage regulator.
              Blow out, if any, debris out of carb air bleeds.
              Check throttle shafts for wiggling.
