360 runs great one day and then poorly the next
For the OP's issue would it be possible to take a video of the engine running badly? Being able to hear and watch it run might help with diagnosis...
How did you make out? Were you able to resolve your issue? I have a similar issue with my 273 and it is driving me crazy.
Please let me know .
Thanks
Is the throttle shaft wiggly?
That causes an intermittent vacuum leak.
Sticky advance weights, rusted plate.
I make my own bushings for my MSD distributor for instance and the metal I use which is basically a little nut I grind down into a egg shape rust's overtime if you don't cover it in a little bit of light grease or oil dot-dot-dot next thing you know the things stuck with initial timing or even sometimes it would stick at full advance 24/7
i'm late to this party and haven't read all the posts but i had this exact problem and a new ignition module solved everything.
