[SOLD] 360 Short block +
Robert Dart
Burley, ID
1978 360 short block +.
Eagle rotating assy. Hypereutectic pistons. 10:1 comp.
Comp cam #20-670-4 installed. Lifters and springs included.
Includes oil pan, pump, pick-up, timing chain, harmonic balancer and water pump.
Also includes a US Car Tools engine dolly. Engine is assembled. Engine has 4000 miles on it. Ran well. About 400 hp. $1500.00
I can meet to deliver engine within 500 miles of 83318. Also, I frequently travel to So Cal. Can deliver on I-15 corridor or most anywhere in So Cal. Also, going to Phoenix area over Xmas.
Selling engine because I had a 408 built.
I have other parts--rocker arm assys., Edelbrock Air Gap, Billet distributor and coil and wires, valve covers, etc. I can make a package deal.
I cannot answer crank question. I did not build/spec. I purchased running engine after build as per above description. Is there a way to determine forged vs cast from exterior inspection?
Look at the harmonic balancer and see if it has the offset weight on it. Or look at the torque converter and see if it has balance weights or if it had a b&m external balance flexplate.
Hello,
I am interested in buying your 360 Shortblock Engine.
The only issue I see is if we can agree upon a reasonable place to meet.
I live in Oakland, California. I think I could drive about 220 miles to meet You.
For example, Reno or Carson City Nevada would work for me.
Do You have any plans to drive within 250 miles of Oakland California in the near future?
I'm available everyday for the next few weeks.
Please let me know if you can see some way to make this happen.
Thank You.
Sincerely,
Robert M.
