360 short blocks
mikey parts
moonachie nj
Does any one know if the p4876907 or p4876908
short blocks are still available
some one told me they were discontinued?
I'd stay away from them. Check out if you can get a refund if the short block isn't what it should be before you purchase it.
Driverside bank had positive piston deck height while the passenger side had zero. (It could have been the rods ill preped.)
My short block came with a milled deck. Just one side more than the other/ It was evident when the heads went on and were far from lining up.
Thats sad,that you cant get a shortblock from mopar thats in worse shape rebuilt than used. I have heard nothing but horror stories about there crate engines for years.
I dont know if they are good or not, I'd think they are, because of Summit's availability..Not that the date's accurate, but if they were axed, Summit wouldnt keep any delivery date. Mancini has a 360 short P5007549 (Magnum version, hyd roller cam, etc.) in a clearance sale ad on the site..$1300. Personally, I'd question that purchase like the others did...
