fishy68
Tyr Fryr's Inc.
I unbokted both headers and im just leaving them in. I need a cheap rebuild option and opinions. Build this 360 again or just leave the car off the road and build a 408 out of it. Block is punched 10thousandths. I also have a 340 thats around 390hp i could buy around july. It has 9.5 compression, forged rotating assembly, mopar purple cam i think. He also has a set of brand new aluminum heads that need to be milled to clear the dome pistons. Throwing in a set of hooker headers for $4k. What do u guys think?
You need to research prices and see what's the most viable option for you. Obviously building a stroker is more expensive. If you have the green that's fine as the extra torque they produce sure is nice on the street. Kinda like having a mild big block in a small block package.
As for the 340, if he has receipts to prove everything is what he says it is ok. No receipts and I wouldn't touch it for half that money. And saying it has a Mopar "purple cam" means absolutely nothing at all cause there are about 20 Mopar purple shafts.
