Ok. I have recently rebuilt the 360 that was in my dart. Got it all put together with the correct clearances and such, broke the cam in and have been driving it off and on for the last few weeks.
But.... The engine is vibrating, when it didn't before. All I did was new beArings/rings/camshaft.
The engine has a 360 balancer that is new with the corresponding b&m flex plate and a neutral converter.
It vibrates from idle to about 1800-2000rpm after that its smooth as glass and pulls like a freight train.
The motor mounts are new. It doesn't look like the exhaust is touching anywhere but it does seems very rigid even with rubber mounts. It does seem that the trans mount needs to be replaced..will that cause it to vibrate in park/idle?
Btw the spark plugs looked beautiful when I pulled them.
I am at a loss :banghead:
