iknownothing
New Member
I have many questions regarding my first true engine build.
Reman assembled 360LA was my starting point. I installed high rise dual plane intake, rebuilt 4bbl Holley 4610, shorty headers, double roller timing chain, Hugh’s Street Force 3 flat tappet cam, 2,400 converter.
My question is, I measured intake valves on the heads I was given and seems like they are 1.88. I don’t know what that means they came off of. They are currently bolted to the motor so what would be my best option for valve springs. I’m on a budget but will buy what I need. I don’t want to machine heads to fit valve springs. Cam says 0.465 int./0.470 exh. On factory rocker arms. I’m using factory stamped rockers and arm etc. Would 340 replacement springs be best and I assume fit? Any ideas? Also, any tips or tricks or anything like that would be appreciated. Even if it doesn’t involve this
