360LA One Piece Oil Pan Gasket?
fenderman33
Portsmouth, VA
I tried searching, but couldn't find what I was looking for. Is there a source for a one piece oil pan gasket for a 360 LA motor? The descriptions on Summit's site are unreliable I've found.
Thanks,
Jon
dont know if there is one for the LA motor...there is one for the magnum motor.
and you need to use the magnum pan with it....or you will have a leaker
what's the difference between the Magnum and LA pans?
FWIW I ran a one piece gasket on an LA 360 with no problems.
top is LA, has notch with hole to anchor gasket
bottom is Magnum
photos courtesy of Old Geezzer
SCE Gaskets made one part # 269091
Looked on their website said they were all sold out .
Summit does not appear to stock them anymore .
Maybe they did leak ,mines still in the box fwiw.
i know djvcuda has a magnum one piece gasket on his LA. we just had to fill that notch with permitex. no leaks.
