femtnmax
This is for a street driven build.
Is the 440source kit good quality, or would you recommend someone else? Is the crank machine work accurate, or does it need to be redone? Is the balance job accurate or just oem tolerances? I assume these kits internal balance?
Cylinder heads: I will use factory rocker shaft geometry, but I could fit a cam to 1.6 ratio. Are the cast iron cylinder heads cheaper/better quality than aluminum, though Id prefer aluminum heads for the weight saving. Do you recommend 440source, Indy, or Edelbrock? Which ever is bought, I am used to taking them apart to recheck everything.
Exhaust manifolds. I was going to use the late 60s factory HP cast iron types. Are used ones ok assuming no cracks, or are they all so-so after all these years of use? I believe repro castings are available, are they any good? Does someone make the flanges that bolt to the manifold outlets, so I can build my own system from there?
Thanks.
Thanks.
