383 A body front sway bar same as 340?
65 Cuda 340
Tallahassee Florida
Right now I have the front sway bar from my non-running 69 Cuda 383 on the front of my 67 Barracuda. I know the 383 torsion bars were bigger (.890 vs. .870). Can't remember about the sway bars, though. At some point I will need to put a sway bar back on the 69. Just wondering if a 340 bar would be the same.
Check the parts book available at mymopar.com
BTW the larger sway bars could be had with a suspension package, not specifically engine related.
my 273 2bbl 67 dart has the 892/893 bars and sway bar
the big block bar is bigger than the small block bar.
i want to say the small block bar was 7/8 and the big block was 15/16?
I’m not sure what was used in ‘67 but the bar diameter for ’68’s and ‘69’s with big blocks were .92 in diameter.
Looking in the Jan 68 revision of the 67 parts book, I can only find one front sway bar part number for A bodies.
2462 838
I measured my OEM bar on my 67 Ralley suspension package - 0.874" dia
Side note...
Torsion bars:
6 cylinder 888/9
V8 except 383 890/1
Heavy duty 892/3
383 V8 894/5
