[Found!] 383 A-BODY HP MANIFOLDS
halfafish
Damn those rabbits, and their holes!
SW Washington
I'm looking for a set of HP manifolds for a 383, that (I think) came in 68-69 A bodies. Casting numbers are 2863900 passenger side, 2899002 driver side. Hopefully there is a set out there reasonable priced.
Reasonably priced is long gone .. I payed 1200.00$ 4years ago.. Call mega parts in Coon Valley Wi. 608-452-2045 .. good luck ..fck headers stay true.
The part numbers you listed are for a 67 early 68 the 69 manifold is a lot more expensive 729 is the last three numbers. I have a set of each, but you need to know that the passenger side is getting hard to find as they crack and most have been repaired like mine. PM me for more info, take a good look at the differences...
C body HP manifolds will also fit and can be much less expensive.
c- Bodies r cheaper but have 2 run on some out inner fender. 69 is better only reason on the 69 they mopar opened up the restriction but 4 a any car 67 68 work fine. I have one fast back and 3 sets of manifolds cheap o and a extra K frame.
Thanks to all for the info, but further evaluation says headers will work better for me.
