Dragonsteel
Can anyone tell me what the min-max rod bearing clearance is supposed to be on 1970 383 with a cast crank. Looked around on the net and i'm not coming up with any answers.
Thanks Mike,Probably .0015- .003. Most all engines use that spec. I like .002-.0025 myself. Middle of the road so to speak. .003-.004 is pretty loose. Good for a high rpm race engine with heavy oil.
Yes, everything wiped clean and no oil.Make sure the inside of the rod journal is clean and the back of the bearing halves and re check them. Are you using oil on the bearings?
I'd run .001 and not worry about it.Thanks Mike,
I was coming up with .001 on my plasti gauge readings and it had me concerned.
