[Found!] 4 small bolt steel wheels
Jeff: You probably need to specify if you want the more common 4.5" width wheel or the not-so-common 5.5" width wheel. If you get the smaller width, it does limit the width of tire you can install.
Oh yes I forgot, actually either one will work I'm putting them on a 6 cylinder car, just gives me more options on hubcaps that way.
Thanks jeff
