I'm changing the 74 Duster from 6cyl 3-speed to big block 4-speed. It currently has column shift, so I will have to add a shifter hump. Is there a template available to locate the hump properly? What's the best way to do this?
Also, I have the 4-speed trans/bell housing that I'm going to use, but I've been told that my 6cyl zbar won't work with this setup. Is that correct? If so, I am in the market for those parts.
