4 speed shifter
AW1
Member
Houston
I have a Hurst 4 speed in my 66 Baracuda and I want to change it out. I looked on the Hurst website as well as Summit etc and could not find out what I am looking for. My present shifter does not have a reverse lockout and I would like to change the shifter to one with it. Does any one know of one that I could use? Also are there any straight line shifters that would work?
The old Hurst lockout for the competition plus was simply an add on plate that bolted in between the shifter and mounting pad
hurst-reverse-jpg.1105174
3 speed or 4? Most Hurst 4 speeds are a bit tough to get into reverse anyway. I'm a little confused about the issue.
Hurst Super Shifter, Hurst Ram Rod, and Mr. Gasket Vertigate all have reverse lockout. Ram Rod and Vertigate are in-line shifters, but very pricey when you find them.
Thank all of you for your help. I will look into all of these shifters
