4 speed vs 4speed
Uh..........yes and no.............
Although there WERE 833 OVERDRIVE units made which bolted onto GM bells and had GM spline input shafts. I don't recall what their length was.
Here:
http://www.jalopyjournal.com/forum/threads/help-on-4-speed-w-od-transmission-id.386760/
Once again, that is OVERDRIVE and was manufactured specifically for GM applications by New Process. To my knowledge, no straight A833s were made in GM pattern
Mopar 4 speed and a Muncie 4speed? No, completely different bellhousing pattern. Mopar imput shaft is a lot longer.
Here's another I found on ebay. From the shifter, this is out of a van. To repeat, this would NOT be found in a Mopar, it was built on order, made for GM by New Process. Notice the 10? spline Chev clutch spline
These boxes seem to be known as a NP440 for GM
