mopar7172
Banned
are 400 big block engines any good?i have 73 400 big block.how can i boost the compression up? & get a little more horsepower?
That is not what I have read elsewhere. Maybe you could go into some detail?
People don't talk much around here for some reason. . .
how much more compression&horsepower?The 400 is a great platform to build big strokers out of, but you can still make some power in its stock form as well.
As stated you want some more compression. One way to do this would be to find a set of closed chamber heads. 915's would be prefered but the 516's will work too. Have a good valve job done with some oversize valves possibly some bowl work and you'll make some decent power on the cheap. A mild cam and a dual plane intake would round out the package nicely.
Ted
ok thanks for the advice.OK, I did some "REALLY ROUGH MATH" and switching to a set of closed chamber heads and if you used a .020" head gasket you would bump your static compression up approximately one point. This is based on if your heads are 83 cc's now and the replacement heads are 73 cc's.
We dont know where your piston is @ TDC. By that I mean is it at zero deck or is it way down in the hole. If for some reason it's close to the top of the deck then you will gain some power from the quench area of the head.
Basicly what I'm saying is that its really hard to say what you would gain from doing these mods but you have a good platform to begin with. The 400 has the largest cylinder bore of all the big block engines so it responds well to things such as oversize intake and exhaust valves.
Also keep in mind that you dont want to get too caught up in the big compression game. Yes a bump in compression will usually make more power but keep in mind that you live in the desert and tuning and cooling will be a big factor.
Ted
people don't talk much around here for some reason. . .
If you really want to be impressed, look in the big block tech section for MRL's build on a stock stroke 400 two barrel build. It was built for a restricted race class that only allows two barrells. That's Mike Liston the owner. We have him, Brian from IMM engines (ou812) and a host of others here with a LOT of knowledge and the thing is, they SHARE! There are some AWESOME people here that will help you if you'll listen. This is the best damn automotive site on the net, bar none.
lmao Rick, i didnt even notice , too funny ops:New info. never hurts, but this thread was 1 1/2 yrs. old.
LOL same page again
