408 budget stroker ?
I building a 426 stroker with a procharger trick flow heads .545 .545 cam this 360 la block is going to sing 5000 stall Victor intake can not what
72 dodge dart before the stroker kit 10.40 in the quarter
Im building a magnum 360 for my 67 dart in my research I came across an article or 2 on the ease of making my engine a stroker . Besides the crank and the harmonic balancer what do I need. Read a little that the stock rods will work and I do need to change the pistons. Im on a small budget but if I can rake in almost 50 ci and 75+ lbs for 600 win win. Bit im uneducated on the whole deal.
If you have a good condition Magnum the bores might be good enough with a ball hone cleanup.
Find a set of pistons and a crank, check all the clearances and put it together.
I'd advise looking in the sale section on this site, guys selling good parts there all the time. Don't get in a huge rush and search for deals and you can find them.
You'll drop probably 3-500 on a balance job.
I'm guessing you're sticking with stock heads? Call up Oregon cams for a regrind.
Spend the good money on a good converter and gears.
No matter what you do though you're gonna drop a few grand bare bare minimum.
