Damond Garrett
Bigdemon
I building a 426 stroker with a procharger trick flow heads .545 .545 cam this 360 la block is going to sing 5000 stall Victor intake can not what
Welcome to the site. Oh my, That will be a handful.I building a 426 stroker with a procharger trick flow heads .545 .545 cam this 360 la block is going to sing 5000 stall Victor intake can not what
If you have a good condition Magnum the bores might be good enough with a ball hone cleanup.Im building a magnum 360 for my 67 dart in my research I came across an article or 2 on the ease of making my engine a stroker . Besides the crank and the harmonic balancer what do I need. Read a little that the stock rods will work and I do need to change the pistons. Im on a small budget but if I can rake in almost 50 ci and 75+ lbs for 600 win win. Bit im uneducated on the whole deal.
What block?I building a 426 stroker with a procharger trick flow heads .545 .545 cam this 360 la block is going to sing 5000 stall Victor intake can not what
