408 dart sport
I don't think I will ever do this again
Should have just bought a roller and went racing
Ok the body work from the doors back is really close looks killer with just the epoxy sealer on it should be close to perfect with the high build on it
It's really hard to believe how long this is taking me. I work on the damn thing all the time it seems anyway this is where it's at
Your work really is showing! Everything is razor sharp! Better than factory for sure!:thumbsup: i wish i could comission my dart sport to you. Awesome!:D
That's exactly how this all started
I have had the car a long time
Had a guy do a cheap paint and body job on it about 15 years ago
And it was just time to update car
hang in there ! It looks great !
What are you running for a rear suspension?
From the looks of the pictures he has in-boarded Cal-trac mono leafs, Cal-trac sliders instead of rear shackles and Cal-tracs.
I'd be interested to know which height mono leafs he is using.
Car looks great, are you running stock steel bumpers or fiberglass for your weight reduction? The crash beams bolted to your stock bumpers weigh a lot. Way lot more than the bumpers themselves. Saw a guy on here use the 70-72 duster rear bumper on a 74 and tuck it in tight. Got rid of those 5mph impact bumpers.
Fiberglass hood both bumpers
Deck lid Lingenfelter bumper brackets
All under coating has been removed which was roughy 45 lbs and a pain in the *** to do probably not worth the time
Crash bars in the doors has been removed
Areospace brakes in the front with a tubular k member, Viking coilovers
Got the filler primer on the car
Just by chance I used evercoat polyester
Finish sand primer and I have to say that it did everything by they said it would do and then some very happy with there product
Should be painting the car this weekend
Not a big fan of a big gap between the tires and fender Even tho I seen a few that look pretty sweet.
you must be lookin at a diff. pic than I am ! I like it, very well proportioned .
