swinging74
Member
I'll be building my first smb and i was wondering what you guys think the hp i could get from my set up,
-seasoned 360 block
-scat 408 stroker rotating assembly
4.030 bore, hypereutectic dished pistons, 10:1 compression,4.000 stroke crank,6.123 rod length
-INDY LAX heads, 3 angle valve job, 1.92x1.625 and hard seats,5/16 stainless valves, .525 lift spring valves, 7 degree locks and viton seals, chrome moly retainers, cast iron valve guides, 2.02 intake valves, mill cnc and correct chamber, full port and polish, intake port volume 179cc
-big mutha thumpr hydraulic flat tappet cam, lift .507/.494, duration 295/312, rpm range 2500-6400
-comp aluminum roller rocker arms, 1.6 ratio
-mopar performance single plane aluminum intake
-750cfm mighty demon carb, Billet Baseplate with new Idle-Eze,billet metering blocks, Patented Concentric Venturi, nochoke horn, Replaceable Air Bleeds, Replaceable Idle feed restrictors, Mechanical Secondaries
Patented Large View Sight windows, Dual inlets, Metering blocks with tuneable jets(Primary and Secondary circuits), 4 Corner idle adjustability, Built-in Power Valve blow out protection, Vacuum ports - 2 constant, 1 ported, Most common tuning parts interchange from other manufacturers(Jets, Power Valves, Squirters)
If you need more info please just reply and ill respond.
Also ill be running a tci 904 automatic trans reverse manual valve body and 2800 stall
-seasoned 360 block
