69PSSWINGER
Active Member
Just got the 416 installed. Just wanting to find out what the redline should be. Has steel crank , H-beam rods,beehive springs ,Crane Gold roller rockers, balanced. Was built by Diamond Back Racing Engines. Thanks
When it throws a rod, you've found the red line.
It's hydraulic...6200 is it, but you will know...when you feel it start to lay over at the top of 2nd, you just passed it.
shift went you hear the rod bolts stretch..........
meh........I spun my chevy 327 to 8800 a BUNCH with a BIG hyd cam. Was still pullin too.
I believe Damon would have built your block, and he is a member here, but comes infrequently.Just got the 416 installed. Just wanting to find out what the redline should be. Has steel crank , H-beam rods,beehive springs ,Crane Gold roller rockers, balanced. Was built by Diamond Back Racing Engines. Thanks
