replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,093
- Reaction score
- 8,055
Hate to see this go, but I aint ever going to have a car worthy of it so......here goes. 1966 HEMI, was a running engine, was dissasembled and taken to the machine shop for cleaning and inspection. All parts were full magnufluxed, there are NO CRACKS!! The block is .030, and still looks good, NEVER blown up or welded on, the crank is the correct 8 bolt unit, and is still std/std. Looks like factory rods, not sure on the pistons maybe TRW. 2 pistons have the top ring land pulled up in a spot, was told they could be repaired. Has a Crower solid roller cam, unsure of the specs, but there are numbers on the cam. Heads are nice, NO CRACKS, No porting or grinding whatsoever, has had bronze guilds installed at some point. All the bearings that came out were in good shape, could of left it together.. Factory rocker gear all nice, def not worn. Engine had sat untouched since the mid 70s untill recent. Looking for 9000.00, PM for any questions!!
