42rh/42re trans identification
modart440
looking at a 94 Ram with a 3.9 v6 auto. How do you tell if its a 42rh or a 42re trans.
thanks.
I believe the RH has a 3 pin connector (OD and lockup) where the RE has "many" (8?)
This is addition to the "same old" neutral/ reverse switch.
RH means "Hydraulic", RE means "electronic"
