[WANTED] 440/727 kickdown stuff
I have a set all original parts including throttle cable bracket and 727 trans valve body lever the only piece i am missing is the one rod which goes from the throttle bracket lever to the trans bellcrank. PM me if interested
Lokar makes a trick piece, for $75 or so. its a cable so it fits all cars..... I found a motor home setup cleared and worked on my 67 Dart....
I have that kickdown cable was 75.00 55.00 I will ship it to you you just need the kickdown arm and the cable runs up to your carb and you adjust to where you want it to kick down at . pm me if interested
