For me that would be very predictable...Diagnosis by keyboard is virtually always a teeth pulling exercise..
. Don't mind me. I am just a dentist..After watching the video of this engine idling, I'm curious if the timing is stable. If the distributor has light springs, the advance could be bouncing and that would make the idle hunt up and down. A quick check with a timing light would either prove that condition or rule it out.
Sure seems like a vacuum leak.
Do you have a sure fire way to find this out? I tried the propane and carb cleaner method. What areas would you suggest? I tried all connections to the intake manifold and carb.
Some of the Holleys you do not need to drill the throttles. Instead there's a stop screw for the rear barrels you can crack the rear butterflies (secondaries) with the stop screw instead of drilled bladesTry this. Forget the timing light temporarily. You must adjust back and forth between timing, idle speed screws, and idle mixture
Try timing it with a vacuum gauge or tach for max RPM/ max vacuum. Warm of course. Adjust idle mixture screws for max RPM/ vacuum and keep backing down speed screw to keep it within reason of idle speed. When you have it running with timing at max RPM, retard timing just a bit, until RPM/ vacuum barely drops/. At that point readjust mixture and idle RPM and then grab the timing light and see where it sits
YOU MAY HAVE cam timing off some do you know where it's degreed?
I will have to see if there is a screw for the secondaries. I didnt notice one before.Some of the Holleys you do not need to drill the throttles. Instead there's a stop screw for the rear barrels you can crack the rear butterflies (secondaries) with the stop screw instead of drilled blades
| Operating Range: | 1800-6000 RPM |
| Duration Advertised: | 274° Intake / 286° Exhaust |
| Duration @ .050'' Lift: | 230° Intake / 236° Exhaust |
| Valve Lift w/1.5 Rockers: | .490'' Intake / .490'' Exhaust |
| Lobe Separation Angle: | 110° |
Actually it's this cam. Made by Elgin, melling, etc. I also degreed a mopar performance magnum cam. Same specs.Here are the Stock 440 Camshaft specs so you have the numbers to compare things to:
440 Stock Cam
P4452783
.450 / .468 Lift
268* / 284* Duration
@.050 208* Intake
@.050 221* Exhaust
113* Lobe Center
Original 440, Commando, 383 Magnum etc.
