moparlee
64 Valiant
I hope this is alright to ask this here? I've had a short block done by J.D. Engine & Machine a couple of years ago now.....but I'm just now trying to put some miles on it.
Here is break down for most of it:
SUM-K6400 Summit Cam and Lifter Kits
Cam and Lifters, Hydraulic Flat Tappet
Advertised Duration 272/ 282
Duration at 050 inch Lift: 214 int. /224 exh.
Lift .442/ .465 with 1.5 rockers
Basic Operating RPM Range: 2,000-4,500
Lobe Separation (degrees): 112
Camshaft Gear Attachment: 1-bolt
Recommended Camshaft Style Flat tappet hydraulic
Installed Height (in) 1.800 in.
Seat Pressure at Installed Height (lbs) 121 lbs.
Open Height (in) 1.300 in.
Open Pressure (lbs) 298 lbs.
This info below is for the KB184 piston
ENTER YOUR DATA CALCULATED DATA
Cylinder Head Volume (cc) 78
Piston Head Volume (cc) -2
Gasket Thickness (in.) .044
Gasket Bore (in.) 4.5
Cylinder Bore Diameter (in.) 4.35
Deck Clearance (in.) .08
Stroke (in.) 3.75
STATIC COMPRESSION RATIO 09.40
OPTIONAL DATA Rod Length (in.) 6.758
Adjusted Stroke (in.) 3.255
Intake Closing Point (degrees) ABDC @ 0.050 lift plus 15 degrees 49
DYNAMIC EFFECTIVE COMPRESSION RATIO 08.29
915 heads with 2.14 intake and 1.84 exhaust valves. Steal crank & LY rods. Built with quench. 20 minute breaking time.
The motor is really noisy when you first fire it up. Good oil pressure 70 cold and 40 hot. I really don't know what to think. What do you guys think?
Stroke (in.) 3.75
