[WANTED] 440 pulleys no ps
A Body 440 WHY NOT
Jersey
I am running an alum water pump and aluminum housing . Pro street damper . I have 2small block crank pulleys that will bolt on the 440.
I am looking for a shallow (2") water pump pulley with a small diameter. Or a set of crank, wp pulleys that will underdrive ( spin faster) the water pump.
Nothing fancy . I will be painting them. No AC, no ps, . Alt brackets too if you have them
Thanks
Thanks
I have the two main alternator brackets , new ''chrome'' , u can have for $12.50 plus shipping if u want them . No spacers or anything tho.
Also have a stock single belt 6 15/16'' pulley too -------
whats the diameter of your crank pulley?
ive got these:
1.75" x 6-1/2"
2.1" x 6-5/8"
thanks Bob:)
the smallblock crank pullies I have are over 7".(7-1/4-7-1/2)
either of those pullies pictured would overdrive the water pump.
if your stuck on keeping the small crank pulley this is all ive got that may work. yes its a double shiv.
2-1/8 x 5-7/8:
thanks Bob:)
2-1/8 x 5-7/8:
I am not really stuck on the sb crank pulley, I just happen to have them. If you have a set that will work let me know
