440 timing gears
scampy72
North Carolina
hi all i was wondering if someone can help me figure out how the timing set goes on my 440. mainly the upper gear, but well were at it i guess the bottom too. if anyone can help, and maybe even post some pics? that would be most awesome.
thanks alot guys and happy almost new year :)
Isnt it just "connect the dots" (ie, dot on cam at 6, dot on crank at 12) for an RB?
Bear in mind that MOST engines when lined up that way --the way the books tell you-- the engine IS NOT "ready to fire" on no1. It is instead on the no6 compression stroke
So after you install your new cam SPROCKETS and properly line them up, and put the engine together, ROTATE the engine one full turn before dropping the distributor in on no1
Two ways to tell for sure that you are on the no1 compression stroke:
If the valve covers are off, look at the no1 valves, If the no1 valves are both CLOSED you are on the proper crank rotation, the compression stroke. If they are both open, rotate the crank one turn.
If the valve covers are on the engine, pull the no 1 plug, stick your finger in the hole, and bump the engine on the starter. You might have to "go around" a couple of times the first time you learn this. When you feel compression push your finger out, STOP and look for the timing marks, which should be "on their way up." Now be more careful, bump the engine, or wrench it over until the marks are lined up NOT on TDC, but rather BEFORE TDC exactly where you "want" the timing to be, example, 12* BTDC.
Now drop the dist in with the rotor pointing to the no1 plug tower. An easy way to do this is mark or scribe the top rim of the distributor housing so you don't have to argue with the cap.
On a B/ RB engine, "retard" the dist. is moving the housing CCW. So retard the timing a bit, and slowly bring it back advanced, CW
If you have "points" ignition, advance until the points JUST open, use a meter or light to see this.
If you have breakerless, line the reluctor tip up with the center of the pickup coil.
This method should be close enough that the engine will start and run, timing wise, with no fuss.
kay thanks for that info but i meant on the installation side, as in the bolt(s) i have a bolt and the "oil slinger" but the bolt head is a bit too small so thats the info i need.
The gears (lined up with the chain on) slide on the cam (3 bolt or keyed 1 bolt) and crank shafts as an assembly, slinger goes on before the cover goes on, then the damper goes on through the cover seal (smear it with oil) and then the bolt with washer goes on the damper. That help?
a bit, but i guess the problem is the size of the bolt on the cam. the head of it is just too small, it goes right through the cam gear. pics would be a great help if anyone can get me some.
thanks
marc
ok can i get that for the washer and buy a separate grade 8 bolt from a hardware store?
Yes you can get a grade 8 bolt from a good hardware store or an autoparts store.
The kit may come with a come with a grade 8 bolt ,just make sure before installing.
