[FOR SALE] 451 low deck parts and Ron's toilet
earthmover
in the tire smoke
nc
Loc: nc
Je dome top 451 low deck piston in good shape went bigger on motor don't need the piston anymore 225.00
Eagle hbeams 676cc rods out of the 451 2 rods got hot from oil starving but was fought in time no spin bears at all arp bolts ..mopar bearing..went to different rods with Chevy bearing 175.00
Milodon gear drive not much run time used but in great shape 400.00
Went bigger cubic inches and different set up don't need this stiff anymore..
Pm for your email for pictures I can't load them on here..or send number can send them by text..mike
also have a nos kit for sale power shot 300.00
Do you know what the oversize the pistons are? .030? How about a P/N, what diameter of pin do they use? What kind of compression do the make, have they ever been sprayed?
Thanks!
Ill
Thanks!
Check but I think they 4375 bore on the bottom 315f I had 12.5 compression on mine..i never used the nos..
Toilet is in great shape just going to a 1050 and a fogger ..everything except pump ..its ready to go get your tune right go racing
The best picture of the year drive I have tight now ..its still at the shop gotta pick it up this week..also have a double roller 440source timing set low passes for sell 50.00 all parts are plus the ride..
The Ron's toilet injection is everything needed to run except fuel pump..im going to use it on my new build as I just had it rebuild and flow tested
In the process of moving as well as working so please bare with me..pm if need it sends a email so I'll get it thanks mike
Ok guys talk to the builder he's pushing to buy a new electric fuel pump worried about the fuel return with so much pressure from belt drive injection pump....pump basically new had it rebuild and flow tested fired the car only a few times ..1100.00 complete Ron's toilet injection set up..everything you need to install it..its almost 1900.00 from Ron's..thanks
