468 with a blower ?
swing72
noob to the game
NL ill
so i just bought a 468 with a hampton 6-71 super charger with dual 660 holley carbs for my 72 dart i was wondering if any one has ran a set up like this and what kind of power it makes and what kind of rpms can i take it up too, the cam is a comp cam 620-650 lift cam with roller rockers 1.5 ratio and flat tappet lifters 906 cast heads ported and polished with ferra stainless steel valves punched out alittle i dont know how much. it has brc alum dish piston 8:1 compression,440 steel crank, big block chevy rods, cloyes double roller adjustable timing set, hjc balancer, the rotating assembelly is balaced and lighten, the crank is studed so is the heads, all with arp the rod bolts aswell o yea double valve springs. if you have any info to if this is a good setup or what kind of power it would make that would be helpful so i can prep the chassis of my car correctly thanks
stock so like 8 psi and it has 2 holley 660 carbs on it with mech. sec.
I would guess 750-850 horses...there is a nice green GTX that has a blown 426 Hemi and the guy smiles when I asked him the horsepower question then he nodded his head when I guessed 750
well thats good to know since i got the engine at a steal since the guy was hurting for money only paid 3700 for it and it is a running engine
What are you going to put it in and what about the hood? Make sure you take lots of pictures and post them to keep people interested..take care
