ChargedDart75
Hello all. I have a 2002 Dodge Dakota 4x4 with a 5.9 and a 46re. I recently started having an issue with the truck to where it has erratic shifting. On the way home the other day, when I let off the accelerator pedal it would downshift to 3rd. When I came to a stop, it didn't want to shift out of first. Cold it shifted fine, and it doesn't slip. Today I drove it to see if it would do it again, and now it won't shift out of first unless it's at WOT, then it will go from 1st straight to 3rd. I pulled out the old Mac Scout and went for a drive. The "actual pressure" is stuck at 29, and the temp was stuck a -8*. I will attach the picture. To me, it seems like the governor pressure sensor and transducer (BWD brand less than 4 years old) has crapped the bed. Is there something that I'm missing? I'm no transmission expert, just want to fix this damn thing. Thank you all for your help.
