489 Crush sleeve or Eliminator
Mojoe9955
NJ
I just repaired/setup a 741 center section. Turns out the pinion didn't have enough shims to achieve the correct backlash. I got a Doc Diff installation kit, hogged out the old bearings to make it easy to facilitate adding/subtracting shims. It took about 6 or 7 times to get it right. It's back in the car and all is good.
I'm about to switch from 4:10 to 3:23 gears in a 489 I have. It looks to me if you use the crush sleeve eliminator it gets set up using shims like a 741 and 742, which I found to be a pain in the a$$ and don't see the advantage as the crush sleeve seems to me other to be the easiest way to go. Pro and cons please?
Thanks
I'm about to switch from 4:10 to 3:23 gears in a 489 I have. It looks to me if you use the crush sleeve eliminator it gets set up like a 742, which I found to be a pain in the a$$ and don't see the advantage as the crush sleeve seems to me other to be the easiest way to go. Pro and cons please?
Thanks
They take a LOT of torque to crush and I mean a LOT. More than an impact gun, so if you don't have a way to do that, I would recommend an eliminator. I recommend it anyway, because it makes the rear end a little stronger.
I definitely was thinking about how to go about the crushing part.
I have never built an 8 3/4, but have done many GM 7.5 and 8.5,8.6 and have always used 1/2 impact to crush. Once you get the crush started it becomes easier, but you have to be ready to stop, know how to feel the pinion tightness, too much and you start over. I think the torque was 30inch lbs on new pinion bearings, 15inch on old. But the 8 3/4 crush sleeve is really beefy !!! No wonder guys are using eliminators.
8.75" Rear End Torque Specs
All specs are lbs-ft, unless noted
Bearing Cap Bolts 90
Ring Gear Bolts 55
Pinion Flange Nut:. Min torque
Small Pinion. 741 120
Tapered Pinion. 742. 170
Large.Pinion. 489. 240
Yeah, but that ain't the same as what it takes to crush the crush sleeve. Not by a long shot.
Crush sleeve doesn't know or care if it was pre-crushed.
Couldn't get crush sleeve for a while back 1970's, my mentor went next door to the machine shop and had about 100 - 10 thou thick shims made.
We have never bought a sleeve since, - just add a shim and crush the sleeve a bit more.
We were doing a diff a week for a long time .
I've reused so many crush sleeves and just tightened it down "a little more" that I've lost count. Never had a problem. But sho nuff as I recommend it to someone, their chit will tear all to heck and back.
You may be thinking GM RRR,
They were 210 ish IIRC.
Maybe, I don't know. I DO remember getting on a 3/4 drive ratchet with a 5 foot long pipe to do one one time. We got it done, but it took three of us. Two on the ratchet and one holding the brake HARD because the parking brake would not hold it.
The 30inch and 15inch lbs is the rotating torque of the pinion gear via the nut only after you crush it. Yeah it takes a ton of torque on that nut to crush the sleeve.
I'm probably going to get new stuffs for my 489 as I don't know the condition of it. I made the mistake of putting the swap meet 741 that "worked good when he took it out". I put it in and it definitely did not "work good". Lesson learned, but I have a hard head.
Asking for a friend...is it feasible to change the ring and pinion using the old parts including old crush sleeve?
I would put the marking compound and check the condition before hand.
The last crush sleeve I tried to use was for a customer and his 489 housing. He provided all the parts to install a 4.10 gear set. I tried to set the pinion bearing preload, had the pinion nut torqued to over 450 ft. lbs. and still had free play. Ended up pulling the threads out of the pinion nut. So I purchased a solid spacer with shims and set up the rear. I have made my own solid spacers for other rears I have set up, and never had any issues
1969 Factory Service Manual diff torques .
Hey rusty, you seem to know your stuff. So i upgraded my pinion yoke n my 489 for my current project and slapped it all back together intending on using the original crush sleeve. It sounds like you have done this before, so when you say "a little more" it looks like factory calls for 240ftlb so what are you saying a little more should be thanks a million!! I was planning on shooting for a little less like 230ftlbs as to not crush the sleeve more but i will take any advice you have to give
What I'm saying when I say "a little more" is this. When you remove the pinion nut any time for any reason, you mark the nut and the pinion shaft with a corresponding mark. I just use a small chisel and mark the pinion shaft and nut with a mark aligned with each other. Then when retightening, I have a point of reference. I call "a little more" about 5 "or so" degrees past the mark on the pinion shaft with the mark on the nut. Understand? In other words, you could turn the pinion shaft so your mark is at 12 o'clock and tighten the pinion nut until its mark is at about 1 o'clock. Use red locktite.
