NightRunner
Magnum Swapped S10
Hello everyone! I wanted to jump in to see if anyone knew of (or could measure) the dimensions of the 5.2/5.9 Magnum mounting points. Instead of using the ears located in the front of the motor, my idea is to use the mounting points found on the orange block in the picture attached. I'm mainly hoping to use SBC mounts flipped, but if I have to use LS mounts that's fine as well. Hopefully the dimensions match up a bit, if not it looks like I'll be getting some metal plate and weld-in motor mounts!
