Budget Build 5.9 for a 71 Scamp
my old 5th ave was cranky and didn't like to start when temps got under 20 with an air gap and 600 electric choke edlebrock carb.....will F/M/J exhaust manifolds fit? they might be easier to find with a heat stove than a 55 year old A body one.....
I have no idea. I have headers and no heat stove.
Hey guys, I had another thread called "What to Do with My Scamp" in which I described how I have a slant- six equipped 71 Scamp with oil pressure problems.
At the end of that thread, I decided to pick up a 5.9 Magnum to replace the worn slant six.
In this thread, I want to chronicle my build and ask some questions along the way.
My goals with this build and swap is to do it as cheap as reasonably possible. I also want to have the engine make decent power, but have great street manners. I have done the hot rod thing, I've had a 440 4 speed, multiple cars with lumpy cam and headers, and this time I want to make something that has good torque but is fairly civilize and super reliable.
Actually, what I really want is for this Scamp to be a dependable, comfortable daily driver.
I'd like:
- Around 300 hp
- Air conditioning
- Power steering
- Cast iron manifolds! Yes, that's right.
- Hoping to reuse my rotating assembly (crank, cam, piston, rods, roller lifters)
Right now my spend is:
$375 for the motor.
Tonight I started tearing it apart. It looks a little sludgey in there, more than I was expecting. Hopefully the bores look okay. The motor had 101k miles, according to the junkyard.
As I start pricing out all the needed parts, I am really shocked to find that the motor itself is pretty much going to be the cheapest part of the build! Crazy that an aluminum intake is now $500. Last time I did this, they were $300.
One thing that really has me worried is the accessory drive. This may break the bank!
I'm looking at a complete set up — initially I was hoping to run the factory Magnum serpentine setup but from what I understand, to do that you have to run the Magnum timing cover, which means no mechanical fuel pump. I'd rather not have an electric fuel pump buzzing away. Is it true I can't use the Magnum belt bracketry with the LA timing cover?
Looking at Bouchillon and CVF, I am at about $1000 or $1400 plus tax, respectively, for a complete bracket and pulley set up, including the AC compressor. Any alternative ideas that may get my my goals be cheaper?
This is the build I'd emulate. J.Rob
I'd like:
- Around 300 hp
- Air conditioning
- Power steering
$375 for the motor.
Copy this build ^^^^^^^ J.Rob
Hey, great build, just read it, thanks J. Rob. Curious, what did you do for a head gasket? A thin one or a thick one?
Also, on the subject of the heated air intake:
I still like the idea of trying this, and I actually have found (i think) a heat stove for an a-body manifold. But the trouble is, to get a 4 barrel snorkel air cleaner that has the thermostatic flap is more difficult than I imagined... most I find are for 2bbl. Does anyone have a 4bbl snorkel air cleaner for sale?
see if you can find any mid-late C bodies or cordobas?
Hey. So the block and heads are at the machine shop right now getting the full treatment. The cam is in Oregon for its regrind. Right now all I have to do is plan and shop for more parts.
Right now I am thinking about ways to up the drivability of the car. Remember, I’m not building a hot rod, more of a spirited driver. Dependability is very important on this build and I’d like my wife to enjoy driving it too. So I’m thinking about cold starts and warm ups. With the air gap manifold, of course I won’t have the warm up benefits of the exhaust crossover passage. But I’m wondering if it’s worth trying to get a warm air intake set up going, the way they did from the factory. I’m hoping that the hot air, combined with the electric choke, will make those cold morning start ups less of an ordeal, even for someone like my wife who has very little experience with carburetors.
Only thing is, all the A body driver side exhaust manifolds i see don’t have any kind of “stove” on top of them. Does anyone know what the factory did for a heat stove on v8 a bodies? Or is this not even worth persuing?
Also, any other bright ideas on the topics of drivability outside of just how the engine is set up (carb, cam choice, etc) The AC will be a must.
The exact manifolds that you need are for sale right now in the parts section. Better grab em while you can and all you'll need is the heat stove thingy!
I found some manifolds nearby. And a heat stove! So we are all good on that front.
A question came up for me. I am planning to clean and reuse my oil pump because it measures in spec. I am consulting my FSM and it says to drill and use a sheet metal screw to remove the retainer cap on the relief valve. Then you of course have to replace the retainer cap. Does anyone know where I can find a retainer cap? OR, do you think I can just skpi this step? I'd like to be thorough, but curious if you guys think this is necessary.
So, I mic'ed my crank and all the journals look like they have pretty much ZERO wear which is great.
I'm planing to polish the journals myself with some 320 grit sandpaper.
Question, a book I'm referencing recommends chamfering these oiling holes. They have some factory chamfering. Wondering if I should do or skip this step? Again, this will not be a high0revving racecar, just build for torque and durability.
I kind of don't want to touch it because I feel like I could mess it up and ruin my crank, also, it will produce some dust that i'll have to be sure to clean even more.
But, if its easy and a good move, even for a 300hp build, I am down to do it and have the tools needed.
View attachment 1716486941View attachment 1716486942
I wouldn't mess with it.
I wouldn't mess with it either. If I was going to polish the journals, I would try to find something a whole lot finer than 320 grit.
My crank looked similar. Guy at the machine shop said don’t mess with it. Realistically you gain nothing by polishing it and risk messing it up
Just make sure the bearing clearance is good. I think the factory spec is 0.0005-0.002” or so. I remember mine being around 0.0015”
Mine looked like that and the shop ground it 0.010-0.010, said it was rough.
Was cheap and I was buying new bearings anyway
Have it professionally polished, if the pro deems grinding necessary..or not then. Trust your pro. You can f-up the finish in a heartbeat, polishing yourself. You also need to be able to measure ovality or OOR. This takes micrometers and feel and interpretation. It's likely the crank is good but I hate doing things barely once let alone twice. The pics make me think the crank may need some pro help..is all. J.Rob
^^^ this
you can **** up more than you can fix real quick with these things.
When you actually see how a crank is professionally polished vs the old "Emory cloth and a boot string" method, it really turns the light on in your head. :eek:
Yeah, I got the idea from my How To Rebuild a Small Block Mopar book. They said to do it at home using 320 grit, which now that I think about it does seem pretty coarse…
Hey, so I am going to be getting back the block and heads this week.
I'm wondering what level of cleaning I should do on the block and heads once I get them home. The machine shop was going to replace all the freeze plugs and oil galley plugs. so those will be on the motor.
But, with temps outside in the 30s now, what do you think I should do for a final cleaning? I'm reading about pressure washers, but is there anything that can be done indoors?
if they hot tanked it and knocked in new cam bearings, then you should really only need to wipe down the bores and give a spritz to the other bits and bobs.
i'm a little obsessive and always double check the oil galleys with a quick brush and then blow out.
