Jarlaxle
This ^^^^^ is the kinda thing you need to listen to. You can tell when someone has actually DONE it VS someone who hasn't done anything in 20 plus years. Ole Kenny there has probably modded more stuff in his lifetime that we'd all like to hear about. I'll also add this. I BELIEVE the Magnum truck manifolds with the 2 1/8" openings will fit the 67 and up A bodies. I'm unsure if they fit with power steering, but I know I've seen some guys here do it. You might look into that as well.
Column shift may also be an issue.
100% times 2 on cleaning the lifters. I just did this with swapping a 5.9 into my 66 Barracuda. the amount of crap inside the lifters was mind blowing. my 5.9 was just as sludgey as yours is, but an hour or so of soaking in Varsol (parts Cleaner) and then taking the retainer clip out and the plunger of each lifter and cleaning them out with tiny brushes did the trick. After getting mine all back together, not a single valve train tick. plus way cheaper than a coupe hundred bucks for new lifters. just be careful not to shoot the retainer clips across the room!
FWIW, Rock Auto has a full set of lifters for $112. They're Enginetech brand, PN L2167.
I emailed Oregon Cams today.
Here is what he said. Any advice? I don't speak cam-ese.
#1429
210/214 @ .050”, 260/264 adv, .506”/.506” lift, 111 sep
#2204
213/220 @ .050”, 265/275 adv, .480”/.498” lift, 110 sep
#1341
218/224 @ .050”, 270/276 adv, .482”/.482” lift, 110 sep
#1634
218/224 @ .050”, 270/276 adv, .528”/.536” lift, 110 sep
#1990
224/230 @ .050”, 276/282 adv, .510”/.510” lift, 112 sep
These are some of the most popular grinds in the area you are looking for, I can move the lobe sep around if you want something different. We can regrind your core for $239, it will take about two to three weeks.
If you send us your core please make sure to include you contact info in the box with the cam.
I don't either, but from 25,000+ miles of driving it in a 4-speed car with 2.76(!) gears, my Hughes 1418 has LOTS of low end-rather than retyping the specs, here's the cam card: https://hughesengines.com/Upload/Cam_Cards_2015/SER1418ALN10.jpg .
