5.9 Magnum AC pump adapter
One thought, since your engine uses a Sanden compressor, you can get various Sanden rear caps for ~$20 on ebay, many choices w/ #8 & #10 O-ring ports. There are 2 types or cap (5 bolt or 7 bolt). However, your rear cap has special mounting holes, so if you need those it wouldn't work.
I've seen that one a few times, but always listed as GM. I suppose I should just grab one and see if it fits.
Hi 67Charger,
If you you end up getting one, please let us know if it works. I know myself and others either have the same question or will in the near future.
Thanks,
Travis
I used the hoses from the dodge truck that have the correct block that mounts to the compressor. Cut the ends that went to the condenser and evap and had an A/C shop put new ends on them.
easyrider
That's the plan if this doesn't work. I received it in the mail as I was pulling out to go to work (second shift). I'll know more tomorrow.
So, it looks like it will work fine if I drill a counterbore in the bottom of the bolt hole to clear the raised lip around the bolt hole on the pump. I'm not going to, however, since I want to send it back and get the same thing with rear exits rater than top exits to clean up the plumbing a little better. I saw a universal swiveling on on eBay that may work better for less money.
