5 speed manual trans for B/RB blocks
danbud61
Active Member
Can anyone tell me if there's a 5 speed manual Mopar trans that will fit a big block?
I know those on the ram pick ups in the 90's fit the small block.
Denis
Dont know about the mopar transmission....but Quicktime makes Bellhousings for Tremec TKO and T56 6speeds. Probably better equipped to handle a B/RB's power level
Lots of 5 speed transmissions to fit a big block. I'm surprised no one mentioned Keisler for instance. They make complete kits for that application.
I've run a Doug Nash behind the big block in my B body car for almost 20 years now. Doug Nash isn't around anymore but they sold the rights to Richmond who still make that transmission.
Andy F, I sure wish I had your beautiful garage and you had a doo wacka doo! I too am a fan of the Nash/Richmond 5-speed. I used one for 2-years in my Super Gas Corvette. It left at 10,000 rpm with 1.20 60-ft times and only failed once when 1st gear on the cluster split in half. The transmission is really easy to work on with the split case and they have a good selection of ratios.
Did I say I covet your garage?
