518,46RH,46RE
tractorfix
Ontario, Canada
Has anyone switching a Magnum to carb left the PCM in place to run the tranny? Can this be done? I know there are kits and other ways to control it but can a factory PCM do it also ?
One problem I see is that the cam sensor is the distributor. I don't know if it would function in that manner without a cam signal or not. It might generate errors that stop the process.
Hall effect as I just found out. That could be a problem. I wonder if I could let the PCM still run the ignition that way I could use the Magnum distributor. I did that on a 89 Daytona. I switched to carb and left the ignition as is and the computer ran it no problem.
If you have / friend/ etc with a running magnum setup, you could find out with not too much work. I built a simple redneck backyard adapter to get a carb mounted on top of the EFI manifold to "test fire" an engine. You could leave everything in place and block the fuel, or even re-route the fuel to a regulator for the carb
This thread:
LMFAO Anybody figure out what this is?
Note that photo is before I swapped the dist. this is a completely non-EFI test
I built this to adapt an AFB to the EFI manifold, front barrels only
Is the trans a 46RH, or a 46RE? The RH can be made to run without the computer if you like, the RE would need a computer, or manual valve body to work.
