5x4 drum to power disc brake kit ABS powerbrake.
RobertP
Pasadena MD
I recently purchased the ABS power brake swap for my duster. I have run into a issue where the caliper hits the lower ball joint keeping it from being installed. has anyone had any experience with this? I am going to try flipping the bracket around and mounting the caliper on the front to see if there is enough clearance.
digging up my old thread. for a quick question and update. mounting them to the front solved that dilemma. called ABS and they provided the longer hoses to work as well. my next question now that my car is almost back together from the restoration is, what has everyone used for extending the brake lines to the master cylinder? seems to only need about an additional 10-12 inches.
to clarify this is the Classic Industries brake conversion kit. its made by the company ABS.
