Hellcat Cuda
Just saw your new home and property. Beautiful place and land nearby. Congratulations on your new home!
If you take the two star/retainer washer things off and take the entire hinge assembly off, you can grind those spring retainers off without issue.So glad I found your thread again after being gone for so long! You’ve come such a long way and are doing very neat and clean work. I stopped (for now) reading after your hood strut install. Very clean and nice and yes, the correct way for installing the struts is piston downward, for the reasons you described. I’m going to be doing this mod shortly and have couple of questions if you don’t mind. When you grind or drill the swedged end of that pin to remove the old spring, is there any tension still in that spring that could cause it to jump out and injure my poor old body? Also, I’m going to run a fiberglass hood, so I’m thinking the 150 force lb. struts would be plenty? (Your hood is steel?). Thanks in advance for your great build thread and your willingness to help others…
Thanks HC, it's all been learn as I go and I have been helped along by many others here and other forums too.So glad I found your thread again after being gone for so long! You’ve come such a long way and are doing very neat and clean work. I stopped (for now) reading after your hood strut install. Very clean and nice and yes, the correct way for installing the struts is piston downward, for the reasons you described. I’m going to be doing this mod shortly and have couple of questions if you don’t mind. When you grind or drill the swedged end of that pin to remove the old spring, is there any tension still in that spring that could cause it to jump out and injure my poor old body? Also, I’m going to run a fiberglass hood, so I’m thinking the 150 force lb. struts would be plenty? (Your hood is steel?). Thanks in advance for your great build thread and your willingness to help others…
Drill baby drill!Yes, I’ve already got the hinge assemblies off the car. I should be able to grind out or drill out the swedged end of the post or pin (whatever it’s called that retains the spring in place). The concern I have is whether or not there is some spring tension there that, when I go to pry the spring from its post, the spring could come flying off with force and cause bodily harm to wherever it may hit me.
Am I making any sense here?
I have the Holley Terminator X for 2003-2006. Mounting Location is TBDIdk if you’ve addressed this already but what are you doing for PCM and harness and where are you mounting the pcm and fuse/relay box?
The fuse/relay box I was referring to is the one that will run all the Hemi stuff. Fuel pump, fans, etc.I have the Holley Terminator X for 2003-2006. Mounting Location is TBD
Fuse/relay box will be in the factory location, unless I am misunderstanding which fuse/relay box you are talking about.
Ah, I have American Autowire Classic Update #510603 full harness for the car with updated fuse block and additional relays and outputs. I have not started the wiring yet. I'll add additional relays if needed.The fuse/relay box I was referring to is the one that will run all the Hemi stuff. Fuel pump, fans, etc.
Thursday Night's storm was pretty gnarly.
After the storm.
View attachment 1716549748After the cleanup.
